R Lock Issues - help ! 😵
(P Lock works fine so its not brake related. The shifter has now become easy to change out. Mercedes recommended a shifter because there was no fault codes for anything. But there was no fault code for the shifter either and I had already tried that. They want $3G to replace the valve body and conductor plate and wont do the plate alone since there are no fault codes. So this turned into a flat DIY, which I was trying to avoid. Attached explains P and R Locks in the shifter)
