Timing Chain Rails replacement DIY - need help !
Old Aug 6, 2019 | 03:09 PM
Bogdan Maturoi's Avatar
Mercedes Benz C230 Kompressor 1.8 w203 M271
Hi all,
I just end up in a point where i can't go on with my job. I've started to change my timing chains on a mercedes benz c230 1.8 Kompressor (w203 m 271), but i can't remove the guide rail tensioner from right side, the one which has three pins. I've removed the one from the head from top,but the two ones i've seen that need to remain there. So,how can i take that rail guide without ripping the whole engine apart? ( the timing cover is already off so i have acces, I've removed the tensioner,the chain,the left guide rail)
