Valeo Radiator - Dated Late 2005
My C32 has a valeo radiator however, the date on the top of the radiator is early 2005 (21/01/05).
The part number on it is A 203 500 39 03 and the valeo part number is RA 1415 876954V A.
Is this an affected radiator despite being later than 2003 or is the issue rectified?
Last edited by alb3rtt; 10-16-2019 at 01:21 AM. Reason: Wrong part number/date, misread
View : https://mbworld.org/forums/c32-amg-c...-radiator.html
Behr is good option
Behr is good option
Don't risk it mate and you will always be wondering if your like me. Good luck
alb3rtt (10-22-2019)
Hi all,
I understand that the radiator is made by valeo however, it was definitely replaced at some point as my car was built in 2002. I had read somewhere that later Valeo radiators were okay and I was just seeking clarification on this but I might replace it incase it is not. Moreover, the part number and date I mentioned was wrong, I had misread it, the correct number on the radiator is A 203 500 39 03 and it's actually an early 2005 dated radiator.
Thank you
Thank you
Hi all,
Thank you
Thank you
I hope everything works out for you regardless of what you decide to do. GL!
