Upgraded Pads and Rotors
Also, has anyone found a company that makes upgraded rotors for our car? I emailed DBA about it, but they did not respond.
I have tried the following pads on my car and here is what I think about them.
MB OEM Pads - These pads are pretty good as far as OEM goes. Good stopping power but they are just too soft. I went through a whole set in 2 driver's ed events and I was not braking especially hard. Good for the street but inadequate for the track and also the dust level is pretty high.
Axxis Deluxe Hi Perf Street Pads - These pads are supposed to be a street/track compromise and I like these very much. I would definitely recommend these. The cold grip is very good and don't squeek at all. Also the dust level seems to be lower than OEM but it is very hard to measure as I drive my car hard. I took these to the track and they grip very well and don't fade as much as the OEM pads. However their durability is quite short. I actually finished a set in 1 day but that was an extended test and tune day so it was about 3 hrs of track time. This fits exactly like stock and also has a hole for the brake pad sensor.
Porterfield R4E - These are my favorite and are more geared towards track and driving events. I use these on the street as well. The grip is very good the cold grip isn't as great as the Axxis but once heated they grip just as good. The best part of these pads are there is soo much pad material
. Fade is much much better with these pads because of the amount of pad matrial and the material has a higher temp rating too. Though I use these on the street they do have tendency to squeek and squeal. I don't mind but most people around do tend to look at you when you brake. It isn't there all the time but I think it has to do with inconsistencies in the pad material. It is probably a small patch of harder metal that causes it to squeal as the squeel developed after a track day and went away after another. These pads lasted me through 2 extended track events (more than 4 hrs of track time) and some street driving and I would highly recommend these for a combination of driving events and street use. Dust level seems less but I really wouldn't know because I used these mostly on the track and regardless of what pad you have when you wear through the pad that dust has to go somewhere. The only downside to this pad is that you can't utilize the brake sensor. I just tied the sensor with a ziptie to the brake line so that I won't have that annoying brake pad wear message.So in general out of the ones I tried I would recommend the Axxis for street use as they have all the best qualities of OEM but are a much better pad. For street/track the porterfield R4E is my choice. I plan to try the porterfield R4 (race pads) next and then see what I like better. If it is a race pad you are after then make sure you choose wisely as our rotor is fairly soft and the pad can eat through the rotor material. I also plan on try the pagid orange and any others that are out there.
There are more pads out there for our car and I think Steve (aka SMGC32) has tried a few others not listed here. Maybe he can comment on those.
Also as for rotors I have only tried the stock ones. I just put on a new one and they are pretty good. I think evosport may know of some upgraded rotors. I also plan on upgrading my rotors so if anybody knows or has tried a different one please post a writeup. Thanks.
Prasith
Also the pad material (and rotor material) can become embedded in your paint as well. I know this happens with the BMW's and if you use it on a rainy day the material can actually rust onto your paint and wheels.
But they are supposed to grip like no other.
Prasith
what about the pagid orange you currently run? How would you rate those. I am actually looking for another set of pads as well and am probably going to go with the r4-r. How are they on the rotors?
Thanks.
Prasith
Does anyone know a good place to get these?
Thanks. - TK
at the stock pad?So far I have gathered that pad durability is an issue, for some brake dust, for some fade, but what really makes them worth the extra cost?
Sorry if these are dumb questions, but I really want to know as brakes and pads are probably my weakest area of automotive knowledge.
Also, can anyone comment on how these big brake kits offer so much more swept area, but usually take more feet to stop from a given mph? Are the car mags just doing something wrong?
Lastly, to what extent have these things been addressed in the C55 AMG?
Seems like C32's Brembo caliper uses Hawk HB181 or Pagid U1427 pad sizes.
Late model Nissan 350Z Track uses the same pads, if it is confirmed it will open up our pad choices to other popular brands (Endless, Project u, Nismo....).
FYI, seems like early BMW 840/850i uses the same pads as well.
