C55 wont start/intermittent. Not CPS?
Battery Tests ok, Alternator just replaced last week, Starter replaced in Jan 2019. I've taken it to an indy mechanic and he can start it every time, no problem. Even when has tried it over the course of a few days. he's probably started it 50 times without an issue. He also says it might be a key problem.
Here is the video https://drive.google.com/file/d/1ogJ...ew?usp=sharing
Anyone ever ran into this?
Thanks for any help!!
Try this:
Turn key on the 2nd position, press brake pedal, turn key to start~! This works of my wife's '06 e350!
Let us know.........
Rob
On the negative side, he did a full inspection and I have quite a laundry list of repairs
-Slow radiator leak,
-Lower control arm bushings (which I knew about)
-Power steering leak
-Valve Cover gaskets (i understand these are common)
-rear pads and discs (I knew about this too)
-motor and transmission mounts
-new hoses and spark plugs
-some rear suspension work I think (i couldnt quite read his handwriting)
Hopefully I can do some of these myself, but yikes that is quite a list.
Not too bad, you can handle it
