Frank's Obsidian Obsession - AMG
#504
MBworld Guru
white and whiter
Originally Posted by Trekman
hay frank off topic but did what did they do to fix that problem with your tranny? was it the intercooler pump?
#506
E320
Originally Posted by FrankW
James, the side badge says V6 kompressor, not V8. I'll need to take you to the eye doctor man. lol ...
Frank you are officially out of control! Remember how you used to be the cheap mod fanatic? What happened? Hehe.
![devil](https://mbworld.org/forums/images/smilies/devil.gif)
#511
MBworld Guru
white and whiter
Originally Posted by Bif powell
What was the damage on that, and how did they ultimately track it down?
Thanks!
Thanks!
the pump actually started dying since I got the HREs that's when I first noticed the problem, but thought it was just a glitch. dated back to last summer. I was wondering why the couple time I went up against a IS300 and couldn't pull away from them like before.
#514
MBworld Guru
white and whiter
Originally Posted by sdsilverm3
Goes perfectly with your color scheme.
How's braking performance in comparison with the stock AMG brakes?
the brake definitely stops a little better than the AMG Brembos due to lighter rotors and bigger pistons. the calipers are also a little wider wich in terms need just a little more clearance.
#518
MBworld Guru
white and whiter
Originally Posted by Blake P
What Frank, you got cheap and decided not to do the rears? ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
