C32 amg diff problems
Old Apr 29, 2020 | 09:52 PM
Nzc32's Avatar
C32 amg, bmw e60 540i,
Hey team I'm new to the forum, having issues with the diff in my 03 c32 amg, scuffing noise I originally thought was a wheel bearing but the wheel bearings seem to be fine. Trying to find a 2nd hand diff but can't find anything out of another c32 are there any other diffs from other models that can be run in theese same ratio ect that won't throw the abs off ect? Any help or advice much appreciated
Old Apr 29, 2020 | 11:06 PM
Oshkoshbigjosh's Avatar
2005 S55 AMG Designo, (sold)2001 ML55 Designo, (sold)2004 C32 AMG, RIP 2005 Volvo s40 2.4i
try finding a diff from an slk32 or crossfire srt6. I don’t know if the c55 diff will work because even though they’re both a w203 chassis the drivetrain is different. If you can’t find anything your only options are to rebuild it or buy a Quaife LSD which is not cheap at all
Old Apr 29, 2020 | 11:46 PM
Nzc32's Avatar
The closest I can find local from a w203 chassis are out of a c320 but the ratio is different or one in a 2006 c180 kompressor but has the same ratio.. Being an amg are theese factory LSD or have hydraulic lockers ect? If I was to put the one from a c320 In would there be any complications with the abs or traction control ect? Trying to avoid emptying the bank completely 😂🤣
Old Apr 30, 2020 | 12:37 AM
honestly you would be safer putting in a diff from a c55/clk55. Anything lesser and you risk damaging your driveshaft. Since you’re already down there I recommend changing the flex discs, driveshaft bearing and mount while it’s accessible. I highly advise you to not put in anything that isn’t Amg or performance built. These cars don’t have LSD’s from the factory. It’s a shame your diff is failing. What’s the mileage? Mines at 176k and it hasn’t had an issue for the past 36k miles since I bought it.
I think your best bet is to get it rebuilt. Buying a used one or even a new one is just gonna break the bank. Maybe even look into doing the work yourself. Where are you located?
Old Apr 30, 2020 | 03:34 AM
Nzc32's Avatar
Mileage is quite high I'm at just over 240 thousand kms I haven't owned for a super long time but I've become quite attached hahaha hands down the best euro I've owned and so much fun to drive, I'm in New Zealand.
Old Apr 30, 2020 | 06:09 AM
I’m glad to hear you’re not just going to dump it. These will be worth something eventually.
here are two from eBay at a decent price but I don’t know how shipping and arrival times would work for you. It’s a worth a shot
https://www.ebay.com/itm/123988744801
https://www.ebay.com/itm/163654300260
Old May 3, 2020 | 12:40 AM
kaixdiego's Avatar
190E, C36, C55, CLK55, ML55
Mfactory makes nice lsd’s for w203 chassis and can be found for a great price.
otherwise like said above if it is not beyond repair, a rebuild would be efficient and could probably provide some upgraded components.
