C55 V1 Radar Install
... im guessing yes, but give it a couple of hours and someone will say if its does or not.
(Waiting on the extra display unit still thinking about getting it)
Thanks for the help everyone!!! You all saved me money!!
If any one needs help feel free to pm me or email me djx18@mac.com
Where should I ground it in the trunk? Is there a specific bolt that i should do it to....theres not too many exposed ones.
I'm also tried using a fuse tap, but I couldn't get it in there with the fuse. After the fuse tap is put in, it is way too thick. How did you guys do it with the fuse tap? Those who did it with a fuse tap, which number fuse did you use in the trunk fuse box? It is the fuse box in the driver's side trunk correct. I have a 02 C32, I'm not sure if the fuse box/slots setup is different from a C55.
Any suggestions?
Thanks.
I guess the problem is either the "Add-a-fuse" is messed up or the slot (#14) I'm plugging it into doesn't have any power at all. I want to try the fuse tap if I can get it in with the fuse. I flattened it with pliers already, still too thick.
Sforza.. how was the install? Any closer pics? I would like to do something like that. Can i just buy the hump and throw it on? Hows it work? Anyone know if it would fit on a c230?
Took 45 minutes maybe. Sort of sounds like you guys are knocking yourselves out.
https://mbworld.org/forums/clk-class-w209/76687-wire-overhead-console-hardwire-v1.html
This was on the CLK W209 forum. Pictures are worth a thousand words!!
