Fuel pump location Right-Hand Drive (RHD) C32
2002 C32 AMG
Dear all,
May I ask if there's anyone on here who has a RHD C32 especially the ones built in South Africa and have replaced your fuel pump?
Which side is the fuel pump located?
Thanks!
Thanks!
2002 C32 AMG
Today was a rainy Sunday morning so I decided to have a look myself haha.
The fuel pump unit is on the right side while the left side has a fuel sender unit.
A previous owner has replaced the fuel sender unit,
Bosch part no 0986 580 340.
I'm planning to replace the fuel pump assembly and now im reassured that I've bought the correct unit,
Bosch part no 0986 580 184.
thanks
Left side, sender unit Bosch 0986 580 340
Right side, looks like original (18 years old!) fuel pump assembly
thanks
It looks like someone already took the cap off the pump. The tabs look hammered by a screwdriver. Keep in mind the bosch part number you provided is for the C320. They run according to the spec sheets at 3 bar instaead of the original pumps 3.5bar and 4 bar at the rail.
Also the C32 has a dual pump bucket.
https://www.fcpeuro.com/products/mer...des-2034703794
Im not saying you have to fork over this ridicilous amount fcp euro is charging but you can find the stock pumps with ease and you only have to replace those.
Just transfer the hoses (leak tight or you'll have long cranks!!!) and you'll be good.
https://www.benzworld.org/threads/up...2-amg.3046526/
https://thefabricatorseries.com/buil...uel-pump-issue
