Lug Bolts
Old Oct 23, 2020 | 07:28 PM
ceefiftyfive's Avatar
2005 C55 AMG
Lug Bolts
Does anyone know where I can find R12 12x1.5 49mm cone seat lug bolts? I have 10mm spacers on in the rear with stock bolts and aftermarket wheels. If not what lug bolts should I get? Was told it should be fine with stock lug bolts on it but I have a bad feeling and don't want to risk a wheel falling off.
Old Oct 24, 2020 | 11:02 AM
eurochargedw210's Avatar
w210 E55
https://otisincla.com/
Old Oct 24, 2020 | 11:42 AM
cm60k's Avatar
Yeah, Otis is really good to go..,,
but while you have aftermarket wheels, should to measure the bolt hole,,
then you have to choose the following:-
* M12x1.5, with (R12)
* M12x1.5, with (R13)
* M12x1.5, with (R14)
-;-ZAYED-;-
Old Oct 25, 2020 | 08:21 PM
2005 C55 AMG
Do I even need extended lugs with the 10mm spacers? Also I dont see any 49mm R12 on the site would I need to get 50mms?
Old Oct 25, 2020 | 08:32 PM
w210 E55
wow, you should probably take your car to a show that knows what they are doing. Do you know what 1mm looks like? Also, no one on here knows how thick the after market wheels are. You need to take some measurements and figure it out.
Old Oct 25, 2020 | 10:05 PM
cm60k's Avatar
^^Fully agree^^
with aftermarket wheels, have to measure the bolt hole for proper bolts spec.!!,,
so risky to play a guessing game with wheels dear..
-;-ZAYED-;-
