Pinging sound and red header
I recommend that you remove your exhaust system to check the header and cats for any signs of wear. I would not drive the vehicle in the meanwhile, to avoid any further serious damage.
Did you record the a video or sound file?
Hope that helps.
Hope that helps.
If you don’t have cats and a single walled header, you can ignore my post above.
Sounds more like a bearing to me. Have you tried running the engine with the belt off(only for a few seconds because everything with a belt is out of operation)? Could also be a bad supercharger bearing.
This would not explain the glowing header on the driver side though.
Keep us posted and good luck!
Did you replace just the TPS sensor or the whole MAF and or throttle body? Many have problems with non-OEM MAF sensors. Buy only OEM or genuine Bosch from a reputable seller. There is a strong possibility that there's a massive air leak somewhere. Did you get everything sealed up?
Swap the old sensors back in to troubleshoot.
Code P0221 is Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem. The accelerator pedals themselves also occasionally go bad. You may have been barking up the wrong tree with O2 sensors and need a new pedal. There are threads here about that.
replaced entire throttle body, besides harness. So new throttle body, new map sensor new tps, new o2 sensors. Everything is oem from fcpeuro.
Did you change the fuel filter by chance? It sounds like you're buying everything OEM, but on the off chance - the fuel regulator is built into the stock fuel filter.
When did the car start running poorly and throwing codes? Were the headers and downpipes installed recently or had they been there awhile? You may need a tune to compensate for the freer flowing exhaust - that may be beyond the ECU's ability to adjust enough without help.
Take a look at the fuel trims, MAF rates, and O2 sensor readings. I wouldn't spend any more money throwing parts at it. Look at the data - the answer is there somewhere.
