What are C55 stock tires pressure?
Need to know urgently
cnt
cnt
look inside your fuel door or on the side of the b-pillar
Quote:
Front 2.6 Bar
Rear 2.7 Bar
tksOriginally Posted by mike82y
should be:Front 2.6 Bar
Rear 2.7 Bar
what s that equate to psi ?
cnt
Quote:
225/40 R18
255/35 R18
mike
I thought my C55 stock tires areOriginally Posted by mike82y
thats for the following combination though.225/40 R18
255/35 R18
mike
225/40 R18
245/35 R18
...cnt
225/40F
245/35R
The gas cap indicates to put 33/37psi, but I put 35/39, even w/ the increase in psi, somehow the fronts always look a lil' flat....
245/35R
stock 18" for C55 are 225/40/18 and 255/35/18
ExploreSuper Member
Quote:
my rears are only 245's...I even went out on lunch to check... and this is what's posted on MBUSA....
Tires 225/40 ZR18 front, 245/35 ZR18 rear, high performance
then that's very gay... Originally Posted by DbleNckel
I must check mine then....
cnt
Quote:
cnt
well, DbleNckel said it's the same size as you posted. So i'm not too sure now. Originally Posted by cntlaw
I must check mine then....cnt
but for us C32 who's upgrading to 18s we're running 255/35 rear to keep the circumference the same/close to oem as possible. Also, before AMG changed the format of their site, they used to have the size of the wheels and tires on there, and they said 255/35 for the 18s rear.
i think it is 245 in the rear, ive seen the new SLK up close with the AMG package and they were running 245/35 in the backs..not sure why though.
245 35 18 is a new size for 18's that most manufacturers still don't make, with only a few in the market at this time.
225 40 18 / 245 35 18 is much closer to stock than 235/255's. 225/255 would be the next closest with less spread front to rear. 235/255's alter the front to rear balance the most, at a difference of .38" vs the stock .26". BMW prefers to equip its M3 with 225/255's to get the closest spread between the front and rear, which is .06". The 235/265 combo would be the next choice with a difference of .10" front to rear. In 17" sizes, the 235/255 upgrade works much better in the math calculation with only a .29" difference.
225 45 17 = 24.97" diameter
225 40 18 = 25.08"
235 40 18 = 25.40"
245 40 17 = 24.71"
245 35 18 = 24.75"
255 35 18 = 25.02"
265 35 18 = 25.30"
225 40 18 = 25.08"
235 40 18 = 25.40"
245 40 17 = 24.71"
245 35 18 = 24.75"
255 35 18 = 25.02"
265 35 18 = 25.30"
I took a closer look on my C55 RHD made in SA
Stock Pzero tires
225/40 18"
245/35 18"
and, tire pressure psi as written on the fuel tank cover
F33/R35 for 3 persons
F33/R38 for 5 persons
therefore, I have no idea why some here said their stock tires are 225/255
Stock Pzero tires
225/40 18"
245/35 18"
Mine came with 225/40 and 255/35 and some of the CLK55's on the dealer's lot have this size too. I think MB is using 2 different size tires on the rear. Could be either production availability or last minute change. Those pressures are a joke though. They always set up the rear too high & front too low for optimum handling.
Don't you love the stupid blind people who you have no clue how they function???? Well this person sounds like one of those! JEEZ, just open your drivers door and LOOK DOWN IDIOT.
Quote:
Most ppl here have been very helpful, by no means that a war should be here. Originally Posted by nicedeboy
BTW, the tire pressure of C55 is behind the fuel tank cap, not at the doors.
I also don't agree fortune people here can drive a MB should make joke with the blinds
Please enlighten me if I have said something wrong here.
cnt
Quote:
If you are going to make fun of ppl, at least make a proper sentence out of it, please. You make yourself look like a hypocritical moron.Originally Posted by nicedeboy
Relax Dude!!!
Currently Active Users (1)
