Want to buy c55 amg
I’ve been looking around and want to buy a c55 amg. What should I look out for?
how many mile is too many?
is the rear main seal really that bad of a problem?
thank you all in advance, I’m on a tight budget so that’s why I want to plan out any problems that may come across. I’m not sure if a high Mileage one is a good idea.
Also watch out for tail, parking lights, and side marker lights that don't work - could be issues with the front or rear SAM (Signal Acquisition Module - basically a "smart" fuse panel), which could be more complex to fix. There are no fuses for these - they are driven directly by chips in the SAMs.
The rear main seal typically isn't that much of a problem, but it can be fixed without pulling the engine - just the transmission. Look for puddles. The other seals shouldn't leak enough to leave a puddle.
As with any car, I'd be more leery of cars with around 200k. Anything short of that should be ok - it's just broken in. Mine is running strong at 150k, but does consume oil. It's one of Mercedes' most reliable cars due to its simplicity, but they are getting old. I still rely on mine as a daily driver.
I will for sure get an inspection by a mechanic done before I sign any papers. Thanks again
Some people get less consumption by switching to 5w40 from 0w40. I don't burn any oil but so far I drive my 55 less than 2k miles between oil changes.
