Engine Oil Light WENT ON...
Old Sep 6, 2004 | 06:39 PM
Rareamg's Avatar
E55 AMG Black on Carlsson 1/6 EVO
Ok, I was driving and all of a sudden my engine oil light went on. I decided to add oil, but I think I added too much now it says I have to much oil. I'm taking the car to the dealership tomorrow to get the oil changed. Anybody run into this issue? How often are you suppose to change the oil??? Sorry for the rookie questions.
Old Sep 6, 2004 | 06:58 PM
Bux's Avatar
Bux
G
everyone runs into this issue ..oil light turns on and take it to dealer ..part of warranty
Old Sep 6, 2004 | 09:20 PM
04E500's Avatar
Its probably a faulty sensor. It happened to me and was told its a common problem. Mercedes true to form, the sensor that is supposed to tell you that something is wrong not only fails to do its job, but causes a problem by its own failure.
Old Sep 6, 2004 | 11:08 PM
Rareamg's Avatar
ok, I will monitor the oil. Hopefully it was just low on oil.
Old Sep 7, 2004 | 02:42 AM
ultraseven's Avatar
C32
On my 04 I actually got the opposite message: oil too high. The dealer had to replace the entire sensor module (not just the tips)
Should be done in only one day. Make sure they drive the car enough, 5 miles or so, to test that the replaced sensor is not another defective unit.
Old Sep 7, 2004 | 06:36 PM
Rareamg's Avatar
Just got my car back from the dealership. So far so good no oil messages.
Oil changes are expensive. 106.00 bucks!!!! They don't offer rental cars if it's a out of warranty expensive.
Old Sep 7, 2004 | 07:31 PM
430's Avatar
430
SLK32
If you want to spend $166 on an oil change they will be more than happy to rent you a car.
Old Sep 8, 2004 | 03:47 PM
mike82y's Avatar
i used to have a 00" C320 and once the dealer has added too much oil at the inspection.. i get those warnings stating that i have too much oil also but only when I drive at the high speed (when the egine gets too hot)...
Just take your cat to the dealer and tell them to remove some oil
Mike
