C32 AMG Intercooler upgrade idea!
I've been brainstorming for a long time now before doing any power upgrades! I've decided going this route! If you have any suggestions please feel free to suggest!
so I'm planning on gutting out the stock intercooler close off all the ports for coolant in/out, sensor's ports.
and remove the intercooler radiator and weld it back shut!! Now have the charged air flow from the supercharger into the now welded shut tank and take the two outlets one for each bank ( which previously went into charged tanks) and route them to two separate V-shaped intercoolers on each side and take the outlets from each of the Intercoolers and route them to surge tanks! Since stock Intercooler is dual pass I dont think two side mounted single pass IC's will create a lag! Also I'm going to have to isolate the cooling system with a reservoir, where ecu will trigger the pump which takes the fluid frm the res splits goes to two IC's and hot water frm there goes to heat exchanger up front cools down returns to the res!
I've attached pics of the intercooler I'm thinking of going with! They're cheap! $120 per IC, compared to alternatives.... 113k guys put SLR's IC's 😂😂🤣🤣
Question is do I need to reroute the MAP sensor going this route? Also where is the charged air temp sensor? If it residedes somewhere in or near the stock IC it'll have to be removed!
please let me know what y'all think!
And no idc about drag times! Top speed is where it'd shine! And of course this setup should help with heat soak for 0 to whatever multiple pulls. But let's see so much work.
