C55 rim questions, offsets, etc
Old Feb 2, 2012 | 07:57 PM
sinister55's Avatar
C55 AMG, BMW 535i, Mazda Cx-7, Nissan 240sx
I have my c55 rims up for grabs
But what does the offsets influence
The rims im interested in had offset of 35 front and 35 rear
Ive heard stock rims are 30 offset front 34 rear.
Thank you, and as always appreciated!
Old Feb 2, 2012 | 08:27 PM
dre5373's Avatar
2006 C55, 1995 C36
Offset is the distance in mm from the center of the wheel to the hub mounting surface (the part of the wheel that is in contact with the hub). Assuming you are sticking with the same wheel width as your stockers (and that 30 is the correct stock offset, I don't recall...) then the new wheels would be 5mm closer to the suspension in the front and 1mm closer in the rear.
Old Feb 3, 2012 | 03:37 PM
sinister55's Avatar
Thanks a lot man, i wasnt sure if it was 5 inward or outward
Would i need spacers?
Old Feb 3, 2012 | 07:55 PM
dre5373's Avatar
2006 C55, 1995 C36
Thank guys like FrankW and phister, they enlightened me with their knowledge I don't think you would have a problem with an et 35 front if you are sticking to a 7.5" wheel, my 19x8.5 et32 fronts have 15mm less clearance to the shocks than a stock wheel and I have no issues, but I am not lowered. If you are going wider than that you may want to check in on the W203 forum https://mbworld.org/forums/c-class-w...-know-285.html or if nothing else, crunch some #s here... http://www.1010tires.com/WheelOffsetCalculator.asp
Which wheels are you looking at?
Old Feb 4, 2012 | 02:09 PM
sinister55's Avatar
THey are five spoke amg rims, but they are the rims that came with non-amg motor cars, but the amg package.
The front is 8.5" the rears are 9.5"
Thanks a lot man, again I appreciate it
Old Feb 5, 2012 | 09:33 PM
kent426's Avatar
2005 C55, 2006 Ram 2500 MegaCab diesel, sold 2001 Dodge 2500 Cummins, sold 87 190e-16v, sold 97 e420
SL 55 rims are perfect fit with 265 rear tires or 275 with fender grinding. mine are 18x8.5 ET 30 and 18x9.5 ET 35.
Attached Thumbnails C55 rim questions, offsets, etc-r230-wheel-fitment-table.jpg
Old Feb 5, 2012 | 10:36 PM
dre5373's Avatar
2006 C55, 1995 C36
Glad to be whatever limited assistance I can. With that setup you will have 3mm LESS inside clearance than I do...not sure if that will cause rubbing or not. At et 35 rear you should be fine with up to a 265, and from what I have read, 275 with some trimming depending on the tire brand...assuming you stay on stock suspension. Others can correct me if I am wrong. Good luck!
Old Feb 6, 2012 | 04:05 PM
sinister55's Avatar
I had 265 in the rear and i didnt like them too much, so i went back to 245.
I guess well have to see when they get here
Old Feb 8, 2012 | 07:09 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Check the classifieds...
I just out up a set of authentic amg monoblocks in 18, that's a beautiful setup on that car and works perfectly...
Old Mar 29, 2013 | 09:39 AM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
So, reading this can I assume a stock, non-grinded C55 running 18x8.5 ET 35 and 18x9.5 ET 30, basically opposite offsets, equal size wheels, could run 245s up front and 265s out back w/ no issues?
This is at stock ride height and on stock suspension. No coilover perches/hardware to foul the gig up.
Old Mar 29, 2013 | 04:03 PM
kent426's Avatar
Nope, 245's are too tall and will rub on the inner fender liner at 3/4 turn. You can run 255/30 to keep the tires at 35" height to avoid rubbing or go to 235/35.
Old Sep 2, 2023 | 12:26 AM
SuperMcluvin70's Avatar
2006 C55 AMG
C55 offsets, stock
Here are stock offsets and stock tire sizes. Personally i run a Rotiform wheel w/ stock size tire up front but a 255 in the back with no issues
Old Sep 2, 2023 | 08:07 AM
cdk4219's Avatar
95 SL600
I don’t believe that information above is correct. First off those are the same size front and rear, the c55 is staggered. I believe the offsets and the model years to be wrong as well.
Old Sep 3, 2023 | 11:07 PM
Stephen04E55's Avatar
'09 CLK550, '18 AMG GTR, '06 C55 AMG, '25 GLS450, 09 E63
18 x 7.5" front ET30 and 18 x 8.5" rear ET34
