ABS, ESP, Check Engine Light
If it wont shift out of park it could be the brake light switch. Have someone check if your brake lights are working while youre in park with the car on. As for the limp mode, a brake light switch will not cause that but we can't help you without codes or more info. Did it just happen out of nowhere after the plugs? Is it misfiring? when it is on do you feel the engine vibrating and does it sound odd? Did you do the plugs or take it to a shop?
The classic P0600 and P0720
I do all the work on my C55, Im sure its something to do with the ABS module. I had to manually overide the Limp Mode to get her home but its Strange forsure. It had been like this for a few days but After I turned her off and Back on it would go away. Today it was different, just stopped Shifting and Entered limp. No Misfire issues, No Weird Noises.
i dont know the quality of bremi but i do know that aftermarket coils and wires seem interfere with smooth operation.
do you have any other mercedes with the same coil and wire? The Bosch ones are the best and never cause issues so if yours arent Bosch then it could be the problem.
i doubt its the plugs but there is a tool that you can use to test plugs while theyre running. Not too expensive but definitely helps with diagnosing.
im sure you can find a cheap one on amazon by typing in “coil on plug tester” or by googling. I know this is a far out suggestion but its good to have in a tool box if you work on your own cars. Its saved me from having to rip out every single plug so its worth the investment
