Coolant Seperation
So I want to isolate coolant into 2 separate loops.
1) For engine cooling
2) Super Charger/IC/Heat exchanger.
I've a spare Reservoir from a C320, which doesn't have the additional port which I believe hooks onto the SC cooling circuit, it's the red hose at the bottom at the bottom of the res.
So I'm wondering if I can use the C320's res and put that hose on the secondary res tank?? If you look closely it looks like that bottom red hose connects to the hot IC return line via T connector, what if I put a small res in between those two lines? One end attaches to the top of the res and other one goes back to the Heat exchanger? I know it's confusing but I'm hoping if OG's can chime in! Thanks Appreciate it.
