c32 amg
Old Mar 20, 2022 | 06:30 PM
WC32's Avatar
2002 c32 amg
c32 amg
I have a 2002 c32 AMG. Sometimes it will lose power and feel like the supercharger is not working. If I pull over and shut the car off and start it again the problem is gone temporarily. It does sometimes throw the code for secondary air injection p0410. Many times the check engine light will not even come on. Has anyone else experienced this and if so what did you do to fix this?
Thanks,
Wes
Old Apr 12, 2022 | 03:12 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W203 AMG forum...
prolly needs cooling upgrade...
Old Apr 16, 2022 | 09:29 AM
Mr Oversteer's Avatar
C32 AMG
Most likely the intercooler pump finished. Car will go into reduced power till intake temps drop. Used to happen to me right at the top end of 3rd gear, would feel like a clonk then almost no power for a minute or so then back at it
Old Jun 3, 2022 | 11:36 PM
paqueras's Avatar
G320 CDI, C32 AMG Sportcoupe, GLK300 4MATIC
Johnson pump and heat exchanger. Probably the guys from Eurocharged could help you.
