HELP! My steering wheel and driver seat are bust!
Old Oct 20, 2004 | 12:31 AM
astoroth's Avatar
Hey guys, Need to pick your minds real quick. Turned my car on like usual and the steering wheel and seat failed to adjust. I then tried to move them manually through the buttons and they don't work. Was working earlier today when I took it out. Have tried turning it off and everything. Any ideas would be appreciated. thanks
Old Oct 20, 2004 | 09:29 AM
lap's Avatar
lap
From: Great White North (the one with the crappy dollar)
2002 c32
had a similar issue
but mine was blowing the fuses as well (went through 3 fuses to get the seat to a driveable position). Apparently they replaced the entire motor mechanism (shorting??) and it seems to be working ok for the past 10 months.
Old Oct 20, 2004 | 11:00 AM
jayitx's Avatar
2004 Capri Blue C32
I had a similar problem: mine was working fine, then all of a sudden the seat would not move automatically, but the steering wheel would. Manually, the seat moved fine, but not when I turned the car off/on. I took it to the dealer for Service A and they replaced the whole seat module, but it still didn't work. My SA said to bring it back in because those modules are flaky, but I never brought it back. I recently had a fender-bender and needed the hood and left headlight replaced, and wouldn't you know it.......when I get the car back, the seat works perfectly now!! Go figure........
Old Oct 20, 2004 | 01:35 PM
ggong5150's Avatar
03 C320 (For Sale), 08 Audi TT
I had the exact thing happen to me twice. The dealer says that it's a loose ground wire attached to the control panel which moves the steering wheel and seats. It's a common problem among the C class cars. They will have to either replace the module or attach the ground wire more securely. Doesn't happen to me anymore.
