2002 C32 AMG transmission
2002 MB c32 AMG kompressor
Hello all. Thanks for adding me. My son and I have a 2002 C32 AMG kompressor we have been working on together. The other day it was leaking transmission fluid and so we replaced the pan gasket and filter. Now it won’t go into any gear or move. Put in the recommended amount of 8.5 quarts and it won’t move. Any suggestions? Was fine until we changed. I’m at wits end.
8.5 quarts is about 5 too much if yiu replaced the pan gasket. It only takes about 3.5 for a pan drop. You also wed to replace the wiring connector in the trans as it will leak into the tcm.
