I am driving my car hard.
I also get some rattle noise coming from (it seems like it) the front left panel, above the front left wheel. It's only noticeable above 110 mph. Might be just wind turbulence but I’m not so sure.
Yep, same here...I've done some investigating, and the 2 MAIN rattle problems, is coming from the trunk button (slight pressure on it will eliminate the rattling), and on the rear deck driver's side where the subwoofer resides, the one w/ the HK badge (to confirm, I notice if you place your hand on it and shift it back and forth, it's not securely attached, if you do the same to the passenger's side it doesn't slide back and forth) so as a result it rattles loosely when the bass hits.........for the truck button, i put a piece of clear tape to stabilize it..on the rear deck, I'm thinking of using black electrical tape?
