M3 CSL Top Speed Video
#51
thats the problem with the M3's...our speedo's are off, i forgot by how many percent. But using a GPS would be a good way of telling.
The speedo on the M3's are optomistic by about 5-6 Percent so adjust accordingly.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
#52
7800 in 5th gear = 168 mph on M3
not sure about the CSL...
6th gear...speed limiter kicks in.
so if u wanna do a top speed run on a M, use 5th gear...unless you get aftermarket software.
#53
I thought I read that it had different gearing.
2001 m3 had 3.64 2002-2005 has 3.62? or 63 I can't remember,anyway does anyone know wuts in the csl's rear end.
and I missed the video can some one host it.
#55
M3 CSL...
Gear Type 6 Speed Sequential Manual Gearbox (SMG)
Final Drive 3.62:1
1st Gear Ratio 4.23:1
2nd Gear Ratio 2.53:1
3rd Gear Ratio 1.67:1
4th Gear Ratio 1.23:1
5th Gear Ratio 1.00:1
6th Gear Ratio 0.83:1
Source : http://www.supercarsite.net/e46_m3_csl.htm
M3 6 Speed Manual
Final Drive Ratio 3.62:1
source: http://www.live2cruize.com/bmw_m3.htm
Final Drive 3.62:1
M3 6 Speed Manual
#56
2002 C32 Black/Charcoal
So, assuming no electronic intervention, what is the top speed of a stock CSL and a stock "garden variety" M3?
Given that the M3 speedo apparently can't tell the difference between 150 and 160,
it sounds to me like the regular M3 would be hard-pressed to hit 170, and the CSL might hit 180 with a good tail wind. :p
![tard](https://mbworld.org/forums/images/smilies/tard.gif)
#58
