Stop lights problem on w203
Old Oct 24, 2024 | 03:19 PM
dushko7133's Avatar
Hello to everyone i have wierd problem with my mercedes w203 2002 cdi rear stop lights start flashing but there is no pressure applied to brake pedal i also looked for brake light switch but this car is not hooked with brake light switch it has brake pressure sensor i replace the brake pressure sensor but the problem remains. Soo i try to find what’s the problem and i disconnected the plug from brake pressure sensor the lights stopped to flas and to mention i have no errors on the dash only when im disconnecting the plug.I tried on obd but no errors there for brake pressure or brake lights if there is someone who had the same problem it will be good to share his thoughts…Thank you
File Type: mov
