rear tires
Old Dec 18, 2004 | 10:38 AM
mrkbbd's Avatar
'05 MB CLK 320A; '06 BMW X5 4.8is
rear tires
are the stock rear tires sufficient or would it be wise to upgrade to a 275 tire instead(if it will fit)
Old Dec 18, 2004 | 10:59 AM
smgC32's Avatar
275's are way too large for any 8.5" width wheel. The most common upgrade is 235 front 255 rear. You could stick with the 225 front and select a 255 rear for a little more grip if you wish. Unless you push the car extremely hard, try a max performance summer tire first like the PS2 or SO3 or a DOT R compound and see how you like the difference over stock. Ultimately, if you want to change the handling characteristics significantly, you will need to increase the size of both the wheels and tires.
Old Dec 18, 2004 | 11:50 AM
1313's Avatar
C32, M3 SMG, VR-4, MR-S
Stock Tires
What kind of stock tyres you guys get in US? Mine is Bridgestone RE050. I find it similar to S03 except for the high wear rate.
Old Dec 18, 2004 | 12:05 PM
noka's Avatar
'24 Porsche Macan
MB thinks the stock tires are "sufficient" or they wouldn't sell the car that way.
Maybe you should define what you mean by "sufficient" and qualify it by explaining what precisely you don't like about the stock tires and what you are trying to improve.
Rgds,
Norm
