engine mounts
who is going to do your work?
correction - apparently i forgot where i saw that tech note, but checking on the part numbers at the dealer, the engine mounts for e430, c43 and e55 all have the same part numbers... so whichever ones we use i guess would be ok. i just wished they had somehting stronger and dont really know why they would even pop.
last time it happened to me (on a taurus) was when i lost control on an exit and ended up between the ramp and the exit in about a meter of snow. i couldn't even open the door
i was afraid someone would have to dig me out of there, snow was still coming down.
but . . . i started it up and just drove up the hill, i could not believe it! and neither could the other 5 people who stopped and got out of their cars to check out what happened with me
anyways, have you hit any potholes recently? speedbumps?
i didn't know engine mounts were a problem on a C43
yeah i checked PM and that is where i saw the same part numbers and then called the dealer and they basically said the same thing about the same partnumbers for e430, c43 and e55. no biggie though.
as far as the engine mounts going bad on c43, well i dont know if its common, but they do go bad. the engine mounts on the new MB's are liquid filled unlike the older styles where its just pure rubber. the liquid filled engine mounts are like shock absorbers for the engine supposedly. i haven't hit any potholes nor ever got into an accident - knock on wood, but the roads here in SF are pretty bad, maybe the constant engine shaking ruptured the engine mounts. i really noticed my engine shake when i got my car dyno'd man it looked violent hahahaha, with the new engine mounts, it should be less noticeable.
