Tranny Problem
05' S4 Avant, 91' 300E
Tranny Problem
I know the question has been beatin to death but I would like to know if anybody else has experienced the same as me?
So when I step on the throttle the rpms go up a signifigant amount before shifting. Maybe from 2000 up till 5000 before it actually shifts. Is this a sign of a problem or just normal. I owned a c43 before the one I own now, and I had the same thing, but never thought of it as a problem.
02 c32 89 300e 99 c43(sold)
go get the (tranns) ecu re maped! (MAKE SURE U ONLY DO THE TRANNS)! MB is also known 4 having those great tranns that last forever! hahaha rite good luck!!
none
c43
Originally Posted by NitrogenBalance
Can someone further elaborate on the trans ECU re-map. My transmision has been runing good. However, I'd like to know about everything possible that goes along with this car.
![word](https://mbworld.org/forums/images/smilies/werd.gif)
On my old C43/55 the tranny would hold gear when I'm having fun in the twisties, or wanting a more spirited drive, but when I have errans to run or when my girlfriend drives the car it just puts along and shift normal around the 2k-3k range.
If your tranny goes up to the rev limit and bounces around there before it shifts is a bad sign. Also change out the tranny fluid every 25k-30k miles, and like others have said, re-map the tranny module if you have a 99 c43. The 99s tend to be programed more aggressively from factory and has been known or speculated to cause early tranny failures.
Thanks for all the info. My car is actually at the dealer now. How much do they charge for the re-map or will they do it for free?
Aslo, what kinda tranny fluid do you guys use?
