my C36 '94/95 lacks of power
Old Oct 26, 2006 | 10:43 AM
car maniac's Avatar
Hello everybody, this is my first post. I own C36 1994/5 in Indonesia. it's been awhile I have this problem and all dealers and mercedes garages here don't have the right answers . my cars' problem is : when engine got to warm/normal hot temp. it become lack of power, but when it is cold/ first start the engine in the morning the power is awesome but about 30 minutes or so later power become less.
I would really appriciated if some one could answer my question. thanks in advance.
Old Nov 9, 2006 | 11:26 AM
AWD_Dan's Avatar
'95 C36 AMG '00 Impreza 2.5RS
Rather obvious question, but how do your coolant temps look after you've been driving for a while? Loss of power can occur if there is a problem with flow in your cooling system.
Other idea's?
Old Nov 9, 2006 | 05:22 PM
NitrogenBalance's Avatar
none
The C36 is supercharged right?? So is mine. I can tell you from experience and complaints of 1000's of S/C motor owners that heat slows you down quickly especially during hard driving. A stock car in its OEM configuration shouldn't be losing so much power after 30min that you can really complain about it. If your running 1/4 miles all day than yeah, but normal driving should still have some pull. I would make sure your cooling systems are working properly. A good flush and fill would be a start. Maybe a lower temp thermostat, electric fan controler, etc....
Is the car modified in any way?
Old Nov 9, 2006 | 05:55 PM
HLG600's Avatar
2009 SL63 AMG
The W202 C36 has a N/A 3.6 Litre V6, I believe you are thinking of the W203 C32, which is supercharged. I agree with with AWD_Dan, it sounds like a cooling issue. When was the last time your coolant was changed?
Old Nov 9, 2006 | 06:52 PM
85Cosworth's Avatar
95 Bronco w/351 V8 & 2003 Mustang MACH 1
The C36 has a N/A 3.6 litre inline 6 cylinder.
Old Nov 10, 2006 | 04:59 AM
car maniac's Avatar
car never over heated. when hot stay 90-95'c which is normal. thank's to eurosportAMG & the other guy that post HOW TO CLEAN MAS SENSOR(forget the name, sorry). and no, mine doesn't have s/c.
thank's for the idea. eurosportAMG adviced to clean MAS sensor which i did plus flushed oil tranny w/ changed filter and did the job. now runs great with hot/normal temp. thank's again everybody
Old Nov 10, 2006 | 11:41 AM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Don't clean it! Just purchase a new one. They're cheap. A new one will wake up the car and be more reliable than your cleaned up used original one. Do it right don't half step!
