custom S/C
s/c 99 c43 amg
custom S/C
so i was thinking since i know a couple of people that own shops, of doing a custom charger on my c43 something like a vortech charger, i can get one of my buddys to make me the brackets as for piping and intercooling i can do that myself , maybe bigger injectors , in line fuel pump, etc. what do you guys think, i think it'll work.
none
98 c43
I have been talking to a friend of mine about doing a charger like this. He is running a vortec on a R32 and seeing nice power out of it. My biggest problem is that I am a boost freak. 6-8 psi is never enough. I never really looked into what else is needed for a benz. Software upgrade? Injectors? Larger MAF? Next question is how much can a stock c43 motor handle without blowing up?
READ: S/C CLK Vortech 430
https://mbworld.org/forums/showthrea...9&highlight=sc
Gregg C's CLK55 is a good look too and more descript.
none
The HPS units use oem management as well. In fact alot of lower boost less radicall systems will keep the oem setup. I also believe that kleemann's base kit uses the oem programs as well. I think the deeper you get into power the more has to change. I know mine has been running just fine.
none
Front End Grunting Rubbing Sound???
So this has been going on for a good while. I haven't removed the wheels or any parts yet to look around but I know its there and I know when it happens.
Whe the car is at a standstill and I give it a good stab maybe 1/3-3/4 throttle to get going I hear an initial grunting type rubbing sound for about 1 second as the car gets moving. You can easitly hear and barely feel it. Somthing is defenitly hitting, rubbing, twisting, or such. A second after the car is rolling the noise is gone. Only when starting from a standstill.
If any of you guys are old, it is just like that splitsecond "urrraummphhh" as you get up from a chair and get moving.
I've driven around my garage turing at low speeds up and down the ramps and I can't get the noise once in motion.
Any front end parts that show this sign when they wear out? I would think I would hear it all the time which has me stumped.
s/c 99 c43 amg
98 c43
ET30... Juice?? I wanted to spray my motor as well. I have had nitrous cars before and they are fun, but boost all the time is really really fun. You think if you piece the kit it will cost as much as 4500?
none
Wow I'm a tard....
I meant to create a new topic for this and can't seem to understand why I did it as a reply.....wow.
s/c 99 c43 amg
boost is really fun but in this cars case like i said to make a reasonably good amount of power witch I would be satisfyed with id go with a full standalone system and a couple of other things such as a better charger. yea if u piece a kit together you will probably end up spending that much after everything, thats custom work as well like brakets and stuff like that. but i am really leaning towards a liltel juice, ive had it on my turbo e30 and i loved it, and i know our motors can take it, but not push it of course id go with a 50 or 75 shot. if the hps or kleemen chargers worent so dam expensive then i wouldnt mind doing that but to me for that much money i can have a sick c43 and i know the people to build it.
98 c43
I would love to see one of these cars run on DTA or another standalone system. My mechanic really wants to set up a benz with it. They have had alot of luck getting very serious power from VW's with DTA and turbo installs with a chip. I am going to look into it more. I am interested to know how much the motor can take before.... KABOOOM! also the trans. I would be happy with 500 whp in this car.
s/c 99 c43 amg
id probably go with a tec2 system or a haltech, truthfully it will work im certain u can put standalone on any car i think the c43 with a twin turbo set up with g35R on 10 pounds and some good head studs will make anywhere in the high 400's. i just cant decide what to do, charger , turbo, juice, i dont know but i will do something.
98 c43
I used to have a vr6 jetta with a gt35/40r putting down 487whp. Boost is so fun. Curious why tec 2 and not tec 3? I thought about running haltech before, heard its a real pain to tune. DTA is being tuned around the tri state and coming up with big numbers. I would do a single turbo, just run into a problem with room and mounting. Then the fmic unless you went air to water. I looked into doing that rear bumper mounted turbo system like the vettes use, just too much lag.
There's virtually no room up front.
none
I'm trying to get my roomate to grab that 98' here for 7.7K. It would be subjected to a custom F/I.
Also, check out Rotrex for centri units. The size would be so very perfect for the C43. You may even be able to fit (2) C30's that they make and have a twin charged beast. I think they did this with an M car. They are about the size of an alternator and perform very well from what I understand. Gaining popularity in other markets like BMW and such.
s/c 99 c43 amg
s/c 99 c43 amg
theres always room some reloctions and some getting rid of some stuff would fix that, mind u that if i decide to do this its no longer going to be a nice daily driver, itll deffenatly be a tack car maybe drive it around town once in a while , but the rear mounted kit sounds much much easier to do.
s/c 99 c43 amg
Believe me it would have been done already. I know plenty of folks personnally who have looked at that alternative. The motor and chassis leaves very little room to put a turbo at a cost effective price. It's amazing how they were able to fix two small turbo's on the old Audi S4. And with that V6 in there you can only go but so big.
