odometer doesent light up anymore please help????
Old Dec 31, 2007 | 01:37 PM
tasho3's Avatar
2014 C63 Sedan
i noticed the other day that the odometer doesent light up anymore everything else works fine the temprature is working fine and clock is working fine just the odometer i c see the milage rolling when the sunlight hits it but at night time i cant see a thing....has anybody ever had this problem and if so what could possibly be the problem.......
Old Dec 31, 2007 | 02:58 PM
MBHustla858's Avatar
theres a light bulb that lights up that screen.
replace the bulb.
Old Dec 31, 2007 | 05:12 PM
tasho3's Avatar
2014 C63 Sedan
replace the bulb.
thank you for the info any idea how do i get to that bulb
Old Dec 31, 2007 | 05:50 PM
EVLC36's Avatar
2005 C55 AMG
Pull out the cluster, I usually carefully lever out with screwdrivers, disconnect the two cables on the back, and it should easily come out (fully extend the steering wheel)
Bulb will be bottom middle one, and cost virtually nothing from the stealership.
Old Jan 1, 2008 | 02:18 AM
Kropf's Avatar
2005 E55 Black, 2007 GL450 Carneol Red
This should help:
http://202tech.mkosonen.com/howto/instrument.html
Old Jan 1, 2008 | 04:52 PM
tasho3's Avatar
2014 C63 Sedan
Originally Posted by Kropf
thanks for the link i apriciate it
