what are caster camber and toe settings
Castor can also be adjusted by changing the rear ride height relative to the front.
Basicly lower a W202 will give more negitive camber (a good thing), not change castor (that's fine) and change the toe settings (just have them put back to std specs)
Nothing special you need to know unless you drop the car by a few inchs, then it becomes a geometery problem, not a wheel alignment problem.
would you take it to a local shop or to mbz, i kinda feel the mbz dealer will be able to adjust what little caster that can be adjuster, remember most cast is .5 + - a little, regardless its 225 at mbz and 75 at the local repair shop
IHTH
