Anyone know what size torx bit for airbag removal ?
I located a fairly new OEM steering wheel and I'm almost sure the 2 holes in the back of the wheel keep the airbag in place.
As in other MBZ's these are held on using torx bolts....has anyone done this and if so what size head do I need to get ?
I don't currently have a long shaft torx .
Thanks in advance.
PS- any other tips would be appreciated...other than disco the battery.
Thanks in advance.
500E Signal Rot
Everything you need to know is here, www.2phast.com/500e look under the interior section for how-to on removing the steering wheel.
Thanks !
I remember your C36 page. Do you still have it ?
