C36 Alternator question
Old May 22, 2008 | 01:51 PM
AMG140.6's Avatar
Stg3 B5S4-C55 AMG
if the alternator on the C36 is going bad, is there a warning light on the dash that goes off ? Like an ALT icon. I don't see one light up during igntion phase.
Or is the Battery light the indicator ?
Not sure if mine is going bad.
The other day the car was dead after not using it a few days.
I deep charged the Varta for 24 hrs. It started fine a while ago, so I ran an errand and it started right up after I left the store.I'm crossing my fingers that its just a slightly tired battery.
Is there a voltage test I can run. Would hate to buy a new batt if its the alternator....or vice versa.
Thanks in advance.
Old May 22, 2008 | 02:43 PM
Z06EATER's Avatar
1997 C36AMG
yea there is actually
it will show u a red battery light. this means the battery is not getting a proper charge buddy! but i don't think it's the alt. it sounds like ur battery doesn't wanna hold a charge or, u have something in the car shorting out the battery
Old May 22, 2008 | 04:49 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Just get a charge test on the battery. My C36 is charging fine. It could sit for 2 weeks and starts up with no problem.
Old May 22, 2008 | 05:23 PM
Z06EATER's Avatar
1997 C36AMG
same
here
Old May 22, 2008 | 05:38 PM
AMG140.6's Avatar
Stg3 B5S4-C55 AMG
Just got back from my mechanics.
Looks like the battery might be ready to replace. The long slow charge got it back up to 13+ volts before start up, then peaked to 15-16 volts w/ the car running.
Not sure if it'll stay at that level though.
I'll give it another week, if it dies again, time to get a lighter weight one anyway.
Old May 22, 2008 | 06:01 PM
Z06EATER's Avatar
1997 C36AMG
ok great
don't buy a cheap battery for your car, make sure u buy one that meets the specs....i bought a Bosch for mine, it's 1000cranking amps its for an SL600 lol but i likeded it soo i bought it. once u buy a good batttery it will last one years and also, it won't damage ur lovely car man
Old May 23, 2008 | 01:54 AM
SeeKlasse's Avatar
'98 C43 AMG. Obsidian Blk w/2 tone slvr/blk interior
gettin those v12's to turn over must be pretty tough. i would still go with a dry-cell battery theyre so much lighter...
Old May 23, 2008 | 11:59 AM
AMG140.6's Avatar
Stg3 B5S4-C55 AMG
Arrgghh !
Battery was dead again this morning.
I think I'll get a code reader from Walmart or Autozone to read codes first before I buy a new battery ?
Also, where do I plug it in ? I can't find an obd port in the cabin.
Someone mentioned it might have a bad voltage regulator or module. Would the code reader pick that up ?
.......I have a feeling its not the battery....unless this sucker really needs a strong battery to run dormant. I have heard they do, and that newer MB's even have an Aux battery for secondary electronics.
All the functions do work though. Lights,dashlights,windows,radio...etc. Its just overnight when it all dies.
Sorry for all the ???? , but this is the first time I've experienced electical issues on a car.......in 20+ yrs.
I guess my luck eventually ran out.
Old May 23, 2008 | 12:18 PM
SeeKlasse's Avatar
1. the connection for the code reader is under the dash, sit in the car and put your foot on the gas, your knee should be within about 6 inches of a small black flap witch flips down to expose the connector...
2. if youre still using the oem battery and/or have a very old one in there just buy a new one anyway.
Old May 23, 2008 | 12:24 PM
AMG140.6's Avatar
Stg3 B5S4-C55 AMG
Thanks SK !
I looked at that Varta real close...and for the life of me that is one clean battery .
The terminal,and connectors look super clean.
Either that, or thats just how they age because of them being in the trunk vs. the engine bay.
Old May 23, 2008 | 12:43 PM
SeeKlasse's Avatar
i think thats why mb puts them in the trunk, theres no reason to subject the battery to the high engine compartment temps. having them chill in the trunk is a lot more of a hospitable environment which im sure extends the life of the battery quite a bit...
Old May 23, 2008 | 02:20 PM
Z06EATER's Avatar
1997 C36AMG
yes this is
true, well, i'm not sure about ur battery man BUT DO THIS!
charge the battery full! then let the battery sit with nothing plugged in overnight. see the life of which it stands in the morning. if this is low. then u know the answer my man!
Old May 24, 2008 | 10:24 AM
AMG140.6's Avatar
Stg3 B5S4-C55 AMG
Alternator update
All is good with the C36 !
It was just a tired Varta. New one cranked right up this morning.
Old May 25, 2008 | 01:39 AM
SeeKlasse's Avatar
congrats on a relatively cheap fix to your problem
Old May 29, 2008 | 09:54 AM
OzC36's Avatar
Silver 1996 C36
A new voltage regulator is very cheap to buy online (about $25). They are very easy to install as well.
How old was your Varta battery when it died? I just replaced my OEM batteries in the C36 and also my CLK. Both were 8 years old.
Old May 29, 2008 | 10:47 AM
AMG140.6's Avatar
Stg3 B5S4-C55 AMG
I'd say at least 8 yrs old as it no longer holds 12v.
More like 9.5-10 after a week.
Old May 30, 2008 | 03:54 PM
e34m20's Avatar
n/a
Here are the thresholds for normal status:
OFF - 12.x Volts
RUNNING - 14.x Volts
CRANKING - 9.x Volts minimum
If you are out of any of these ranges, you have a malfunction.
Your RUNNING voltages sound way too high. A voltage regulator problem could be the cause of your battery getting killed. If you don't re-verify your RUNNING voltage, your new battery can be killed in the same way.
If you see a charge voltage of 15v or more, your new battery is going to last 6 months tops. This voltage can also be detrimental to other electrical components on the car also.
