Fuel pump not getting fuel after filter replacement?
When you turn the key ON (ignition) the pump should run until the car has fuel pressure, and then shut off until the engine starts and the fuel pressure drops below the threshold again. Does your fuel pump run incessantly with the ignition ON? or does it run for a moment and stop?
If it was me having this problem, I would fill the tank completely up using a gas can. Next I would turn the ignition on and leave it on for up to 5 full minutes. Then crank the car without turning the ignition off and see if that works!
If that still didn't work, I would re-install the old fuel filter and see if starts.
If it starts, then the new FF is plugged.
If it doesn't start, there may still be air in the system, OR something unrelated has broken while working on the car.
How are you confirming that the FP is running, btw?
To answer your question, I have an assistant turn the key while I have my hand on the pump - I can feel the pump turn on and off.
Thanks again for your help!
I had the same experience exactly.
I found that when I poured about 2-3 litres in the tank it started promptly.
It was later when I took it for a drive I knew something was wrong so went to my auto sparky and he read my fault codes, it registered Emergency fuel shutoff had registered a fault but he didn't know why, at idle, it would drop to 300rpm then over correct to 1200+rpm, straining against the brakes at intersections and sometimes refusing to accelerate as if out of fuel.
I first replaced the engine loom as it was cracked and wouldn't survive the diagnosis then had VAF(MAF) tested as easily damaged by the occasional backfire during its dead starts and it gave dodgy readings, have ordered a new one.
It seems I may have not de-pressurised the fuel system enough/properly before opening the system and the sudden pressure drop triggered a safety fuel shutoff in the system
.Anyone know much about this??????
