Warning: C36 Aux Fan and A/C Pressure Switch Wiring
Old Jun 28, 2008 | 02:57 PM
fstshrk's Avatar
2007 R320 CDI, 2010 FJ Cruiser, CTS-V
If you have not done so, please go to your garage and check the wiring that goes to your aux switch and the A/C pressure switch (attached to the A/C sight glass). I was changing the air filter on my car today and while looking around noticed that the A/C pressure switch wiring was bent at a 90 degree angle by the connector and the aux fan wiring had chafed insulation so that bare copper wire could be seen.
Straightened the A/C pressure switch wire and gave a bit of support by taping the connector at a normal angle.
Also taped over the aux fan wiring so that the wire is no longer exposed.
Of course there may be a wire holder that my car may be missing due to the previous owner, one never knows.
