umm- not to tip my hand here but... HPS guys?
I plan to redo my stereo and make it much much cleaner than it was before with many more little details finished- this i can handle and have no questions about- unless anyone wants help with audio stuff then hit me up.
My air-water set-up has been working well enough and i plan to run a nitrous/fuel injection set-up using a nitrous wet kit. I'm only planning on running a 50-75 shot. I understand that my elevated fuel pressure will require some tweaking of this system etc. and have a handle on that. My current questions- how should i activate the system- do we have a tps signal or will i have to use a mechanical switch? where would you inject the nitrous/fuel? Can i run it all through the blower? it seems liek doing so would result in the best gains as if i can keep the air cool there it will translate to more air in the motor right?
I'm going to be pulling just about all the visible stuff i can out of my engine bay and having it powdercoated by a friend. Anyone have a write-up for pulling the upper intake and valve covers? nitrogen you still want to sell me that intake? anyone have instructions for taking the eaton apart/info about what to use for oil in it (oil has to be removed to pc it)?
if i want to up my boost 1.5 psi or so... what do i need to do to my pulley size wise? I can't go any higher than that without overspinning this blower correct? I know i should also consider planning on having to pull some timing with all of this- but not sure it will really be needed. can i have this done locally at a machine shop? or should i send it somewhere?
lastly, i'm also going to be making a new custom hood out of a carbon fiber one i just purchased. I will likely be venting it with louvers on each side in the front and some kind of a elongated oval vent in the rear center of the hood. Any ideas for where to pick up appropriate louvers or vents to mold in? I like the gt500 ford louvers and possibly the vent off the back of the E46 m3 hood.
hope you read it all and help me as you can
also, now that everyone knows what i have planned- i'll post some pictures as i go... hope i can do everything up to the highest standards, i don't intend to have to redo any of it for a long time.
I've decided that when I'm ready to do this I'm going to send my blower out to stiegmeier and have it blueprinted, rebuilt, polished, rotors stripped, and they can machine the pulley their at the same time. They quoted me a great price of around $495ish I thing and would clean and flowmatch my injectors at the same time for an extra $100. I would consider having the blower rebuilt and blueprinted if you plan on spinning it much faster.
Steigemeier doesn't answer their phones lol- but i'll try some more.
is 2.625" the diameter?
so we all know that if you shorten the circumference of the pulley, and the belt is moving at the same speed it always has, then your revolutions per min will go up. the proportion can be computed easily. if anyone knows the diameter of our crank pulleys and what RPM range the CP spins at, i could compute with ease what diameter it would need to be in order to increase your boost to your desired level. it will come down to how many RPM's the SC pulley spins at, which can be calculated via beltspeed, which is provided by the CP.
the easiest way to find out is to do some research on what RPM gains will give you corresponding boost gains... after that its very simple math, just take into consideration the beltspeed at WOT and calculate which circumference will give you the revolutions you need... for example if beltspeed is 49.5"/s and your pulley diameter is 2.625" (thats 8.247" circumference) then your S/C will be spinning at 6 rps... thats 360rpm's....
sorry if its complicated but the math is simple, you just have to find out the ratio of boost at varying RPM ranges. or if you have a boost guage, cruise at low rpms and note the boost pressure, then coast at 5500 rpm's and note the boost pressure. report these values back to me and i can tell you exactly what diameter your SC pulley would need to be to provide you with the WOT boost you desire... of course i will still be needing the CP diameter and CP rpm range....
