Hood "spring' removal ?
Old Nov 22, 2008 | 03:14 PM
silence's Avatar
sounds like airplane
who has removed the "spring" mechanism of their hood?
I see that there are some "shocks" down in there which i'm assuming provides the spring force. Can it be removed with minimal other work?
thanks
-drew
Old Nov 23, 2008 | 03:54 AM
Z06EATER's Avatar
1997 C36AMG
that is good question i do not have an answer for, however would you mind logging into your paypal and canceling that dispute? i want to purchase some HIDS but i have limited access
Old Nov 24, 2008 | 12:23 AM
2PHAST's Avatar
500E Signal Rot
thanks
-drew
Yes, the shocks hold your hood up. These shocks can be removed, you need a needle nose plyers or a flat blade screw driver, as there are metal C type clips at the top/bottom, pop them out and the shock can be removed.
Old Nov 24, 2008 | 01:06 AM
silence's Avatar
so actually same process as hood or liftgate "springs" on most other vehicles just down in there where it's hard to reach- thanks
