instrument cluster removal question
Old Dec 9, 2008 | 02:08 AM
MIKE COLLINS's Avatar
1985 500 SEC,,, 740 il... 95 c 36 ....
hello all i have a 1995 c 36
(this is a large part of my plan for world domination) however the center speedo cluster lights are out
i had a 85 500 sec and the removal was simple really it just popped out with 2 kinda bent coat hangers inserted around the top side of the cluster and gently pulled out ,,to access the bulbs
does any one know how to remove the cluster on a c 36 ????
thanks all
Old Dec 9, 2008 | 03:54 AM
Television's Avatar
CL500 216
The whole cluster comes out by using the hooks the same way as your old 126,. though I push out from the rear when possible, some do and some are too tight
There are 3 x 2.2 watt lamps inside the cluster and it has to be opened up, the warning lamps are all along the bottom, and easily replaced
Old Dec 10, 2008 | 08:59 PM
kinghais's Avatar
1999 W210 E300 Turbodiesel
thanks all
it's easy . first u have to open the lower panel and there are 4 clips holding the cluster from the back. uhave to put your hand in there(from the bottom to the back of the cluster ) and take them off. and then u can easily put your cluster out.
i've done it
