fitment?
- Center Hub Bore 66.6
- 19x8 Front (ET 30) Tires : 235/35/19 Brand New Sunny SN3800
- 19x9 Rear (ET 27) Tires : 245/35/19 Brand New Sunny SN3800
will these fit on a 1998 c43 with a 2.0 drop?
thanks in advance
yes it will fit... im sure about this...
The front will fit with no rubbing while the rear fitment is questionable.
Offset is too low. Unless you have a modified fender to accomodate the
offset then you will be ok. Otherwise, rubbing will be your main concern
for the rear.
__________________________________________________ _____________
bodybuilding supplements
Heel Pad
