Headlight Problem!
This just happened today turn the switch to low beam will not work but when I flip to high beam both low & high beam works. Has anyone had this problem on their C43 before and solved the issue?
My only source of light driving at night is with my high beam on and I don't want to blind other drivers.
I need advice.
Regards
to add more info I just had my sprakplugs and wire change recently and my mechanic remove the water reservoir, I think something got unplug while doing this task. Called him today and told him the issue I'll be taking the ride back to him to check out the problem.
I did read up on another forum on this issue and it was a main switch problem mercedes fixed the problem because it was a recal on the main switch.
BTW....while doing my plug & wire change also had lowering springs and shocks installed. I'll be posting pics on the other thread, car looks SWEEEEET!!!!
