alot of codes, helpp
po170
po173
po100
po305
po308
po300
po455
po306
thanks guys.
unplugging the battery is not good for these cars, i'm sure u have either a bad coil or bad sparks, how long has it been since u changed em.? your misfire may return..
po173 = left cyl mixture adaption limit
po100 = Mass air sensor
po305 = Cyl 5 misfire
po308 = Cyl 8 misfire
po300 = general misfire
po455 = Purge system major leak, fuel tank pressure sensor voltage supply
po306 = Cyl 6 misfire.
Sounds like you have a lot of issues. Replace mass air sensor & Primary upstream O2 sensors, that should fix most of your problems. Your fuel system may also be dirty, may not be a bad time to check your fuel filter to see if its clogged up, some times that can cause misfire as well.
Hope that helps,
~AMS~
Jeff
Blahuh - Upstream O2s so most of the A/F monitoring and when they get old they go out of spec and can cause you to exceed adaption limits (as can MAF). If the O2 sensors have anything over 60k miles on them I would definitely replace. Because so many codes are going off I do not think its just one thing, its most likey a combination of parts are worn/old and most likely both the MAF & Primary O2s need to be replaced. (secondaries downstream O2s really only measure to see if the primary cats are working and they would pull up a different code which didn't come up).
Hope that helps,
~AMS~
i replaced the maf, new filters, new fuel filter, and i did have a vacum leak, a hose next to the maf was disconected seems to run fine now, as for the coil pack the cheapest i saw were 130 dollars each witch i cannot afford right now.
buy three of these are shop around ebay to find maybe better deals...
http://cgi.ebay.com/ebaymotors/Merce...%3A1|72%3A1171
http://cgi.ebay.com/ebaymotors/MERCE...4506.m20.l1116
thos arent for the c43, i found these its 8 of them for $210, does anyone know if these will be ok?
oh thats right u have a 43,
if it's not bosch dnt get em...you'll be sorry
This is Biitz from UK!
Im new on tis site!...
With those misfire codes I would go looking to see that you do not have a vacuum leak.
The purge valve tubing may be cracked and so leaking, causing the error code and the misfires, because the cylinders are too lean.
Thank's!...
