having a bit of a starting problem lately
Im sure this has happened to you before.
When I start my car I just tip the key and let go as fast as possible. Normally this works unless you let go too fast and the car just makes a sound for a second.
Well lately my car has been doing this even if I hold the key. It usually does it twice in a row before I can successfully start it.
I turn the key and hold it but it still makes that sound as if I did the tip start way too fast.
Any idea??
Any idea??
1997 C36AMG
Any idea??
Any idea??
your starter sounds ****ed
1998 C43
check your trans module for fluid. Could also be conductor plate. Mine has been doing the same off and on. Have codes stored in etc for some sensors on the conductor plate. Just being lazy to replace it.
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
If it sounds like the engine tried to start then stopped to early (before it actually started) then it sounds like you need a bit of lube on the ring gear. Basicly it thinks it has started and turn the starter off before it actually started. It's a old problem for all the M112 and M113's
1999 C43 AMG, 2005 E55 Wagon
think i'm having this issue too! sometimes it blips like its starting and immediately stops. sometimes it starts up but then immediately dies. many times it won't even try to start! new CPS already...
how do you lube the ring gear and where is it?
You have to go underneath the car. At the rear of the oil pan, there is a black cover that allows access to the flex plate bolts. There you can apply a light coat of lube to the flex plate/ring gear teeth. There is DTB a long time ago regarding the engagement of the starter gear on the flex plate, this was the fix for it
'97 c36
Now that makes sense. So it was a tsb for a bendix gear issue. Another member was playing with the crank sensor and some one said to grease the ring gear. Couldn't figure out the connection. Thanks ricecooker
