missing bulb in xenon headlight cluster?
On the 99 C43 w/Xenon the fogs are in the spoiler, and the bottom outside of the headlight cluster is unused. Would it be possible to bulb it and use it for something? Anyone done it?
WTS
I'm not too sure about what you just described, but I'll throw in my answers anyway.
It sounds like you have the Xenon without a highbeam bulb? IF that is so, look into the bi-Xenon for your car.
I am thinking about converting my car, but not too sure what to expect. Plus, I would like all my bulbs to shine like Xenon's.
Maybe post a pic and then describe what you are referring to. That would help alot.
On a 99 C230 w/Xenon there are 3 distinct sections to the headlight: top outside is xenon low beam, inside is high beam, and bottom outside is fog.
WTS
I am in the process of wiring up a relay so that I can choose whether to use the internal foglights (for performance) or the bumper foglights (for appearance).
-s-
DLS- the lowbeam and highbeam are the same on both cars, it;s just the fogs that are different. Sounds like Scorchie has already done what I was thinking about, with positive results.
WTS
You can do whatever you want with these adapters and contactpins...
greetingz,
So ~S~ were you able to work something out so you can use both the bumper foglights and the upper fogs also? Im really interested on coming up with something like that also. Let me know what you have so far. And it is really as hard as I have heard to remove the bulb from the bumper fog light?
