1996 C36 Questions
Old Aug 14, 2009 | 03:11 AM
jdmkutz's Avatar
1998 C230
1996 C36 Questions
I'm currently thinking about purchasing a 1996 C36 w/ 102,000 miles on it for $7500. First of all is that a good price? Can anyone tell me anything about common problems to look for? I don't want to end up putting alot of money into this car. Any advice would help. I listed the car below that i'm interested in.
http://orangecounty.craigslist.org/cto/1286203600.html
Old Aug 14, 2009 | 04:35 AM
svt ricco's Avatar
1999 C43 AMG
ask the seller if he has done the wire harness. it's a common problem for the c36.
Old Aug 14, 2009 | 11:56 AM
jdmkutz's Avatar
1998 C230
If it hasn't been done, what would be the cost if there is a wiring harness issue?
Old Aug 16, 2009 | 07:17 PM
OgdenC36's Avatar
1996 C36
Also head gaskets are a weak part on the c36.
Old Aug 17, 2009 | 07:13 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
A whopping 1300.
Old Jan 3, 2013 | 02:14 PM
sinister55's Avatar
C55 AMG, BMW 535i, Mazda Cx-7, Nissan 240sx
I guess I have no choice but to revive this thread...
I am picking up a 96 C36 (or cosworth, kinda between the two)
The C36 has 6K miles, been in storage for 18 years.
Besides wiring harness, electric gremlins, MAF, and head gaskets....any other surprises to not look forward to?
Old Jan 3, 2013 | 03:53 PM
Vander's Avatar
2002 E55 AMG, 06 C55 AMG, 72 350SL
I would change every single fluid. Where did you find that car at?!?
Old Jan 3, 2013 | 05:12 PM
morganb's Avatar
C63 AMG, C36 AMG, SL500
18 Years! Must be almost new. Any idea why it was put in storage?
I would also check every switch and motor, windows, sunroof etc. Budget for many seals and rubber hoses to be replaced.
Before attempting to start the car (as mentioned above) change all the fluids. I have read but cannot remember a procedure for starting engines that have not been run for a long time. Pretty sure it involved pulling plugs and putting a small amout of oil in each cylinder and turning over (by hand) before trying to start it. Someone else might be able to gvie you the full details or search for this.
Old Jan 8, 2013 | 01:45 AM
sinister55's Avatar
Thanks guys, seal replacement might get expensive, gotta see if I would be able to afford all that, yea +10000 on the fluids I forgot about
I found it on craigslist, cant remmeber if it was NY or CT...
Ill let you guys know what happens
Old Jan 8, 2013 | 03:43 AM
jcmbz's Avatar
C36
I think the wire harness is updated in 96, and with updated AC panel and brakes
but still stick with the leaky head gaskets problem
