Check Engine Light...HELP!!!
99'C43, 88'M5,01'H1
My CEL comes on it stays on 2 or 3 days, goes off then does the same thing again. I noticed it goes off when I fill the tank. Does this happened to anyone else?
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
MAF possibly
Next time you get the CEL go to either a PepBoys or Autozone and have them plug in an OBD II (On-Board Diagnostic) scanning computer so they can retreive the codes - I purchased my own for about $100. If the codes are P0170 and P0173 you're more than likely going to have to purchase a MAF SEE LINK
AMG C43, 1999
Also make sure to look at your fuel tank pressure sender and the gas purge valve. Both of these items are sesitive to the fuel tank and the amount of gas there.
The code should be stored, so they should be able to read it whether the light is on or not.
