Help
Make sure the piston to head clearance is no more than 0.040". Anything more and it slows the burn rate of the cylinder down and you have to use more timinig to make power. The less timing you need the better or more effiecent your motor is running.
I would lighten the crank by having the outer diameter of the crank taken off. And I would find some lighter rods and pistons. Deck the head to up compression to 11:1. Only have the ports cleaned up to remove casting marks and then find someone who can do a really good valve job with your new parts. A really good motor should make about 85 ft-lbs of torque per 1000cc. So your 2.8 can make up to around 238 ft-lbs of torque and if this is made at say 5500 rpm (your max torque peak) then you can make aournd 250Hp out of you motor at 5500 prm. With the new parts find someone who can raise your rev limit to say around 7000 to 7500 rpm to take advantage of the lighter valves and pistons. At 7000 rpm if your engine can make around 225 ft-lbs of torque you would then make 300 Hp.
The next thing to do to really make a difference is get light wheels. You can get 17x9.5" wheels that weight only 15 -16 lbs each and that will make a big change. Remove all the things that are heavy. I removed 250 lbs off my 1st W202 a 1999, C280 and it really made a difference in the way it went and handled.
later....
Mill the head to increase compression to 11:1
Set the Piston to Head Clearance at 0.035" to 0.040"
Clean up the ports but do not increase the the size.
Get a good valve job that moves the 45 degree angle out as far as possible in the valve seat to increase the airflow.
Use a multi-layer steel head gasket and maybe remove one layer to help get the deck height set.
Clean-up any sharp areas in the combustion chamber to help keep detonation down.
Make sure the valves are cut correctly, i.e. check out Smoky Yunicks "Power Secrets" it is a great book with all the basic engine knowledge in one place.
Use new valve springs when you rebuild. The old ones may measure out to the right spring tension, but they won't have the snap of new ones so the engine will not feel as sharp without new valve springs.
Clean everything twice.
have a good trque wrench and use it and also use a very good assembly lube like Redline.
Jeff
