Front Apron Fog Light DIY Repair/Troubleshooting
Old Jun 3, 2010 | 09:47 AM
DRBC43AMG's Avatar
Nice, lets get a bit more confused..... as I love this thread!
In Europe, some years back the light and fogs worked like this:
1st position: parking light or side marker lights on (as you seem to call them over there)
2nd position: driving lights on
1st pull: fog lights turned on and driving lights off
2nd pull: rear fog light turned on front fog lights still on and driving light off
Indicator stalk pushed forward: main road hi-beam driving light on
Today the rule is like this:
1st pull: fog lights turned on and driving lights still on
2nd pull: rear fog light turned on front fog lights still on and driving light also on
So how does that get you
Old Jun 3, 2010 | 05:16 PM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
hmmmmm...... this looks familiar
Old Jun 3, 2010 | 05:17 PM
any other C43 owners want to chime in here?????
Old Jun 17, 2010 | 01:21 AM
So this is exactly how mine work... I thought someone may of changed how the switch works but then I found this on another forum :
You already have front fogs fitted they are in the headlights and come on with the first clic out of the main light switch, with a 43 these front fogs are disabled and the feeds are fed to the ones in the bumper.
To fit them in the bumper you will need to fit either C36 or C43 front bumper c/w with fog lights and 2 wiring looms which just plug into the headlight to get the fog light feed.
SO TO END THIS THREAD, I was right the C43 works just like I explained and I guess the C36 is different or YOUR switch is wrong. Either way we now have 3 confirmations that my switch is wired correctly
Old Jun 17, 2010 | 07:23 AM
appatula's Avatar
95' AMG SeeThreeSix
Not pointing any fingers here but I don't care how many people on other forums tell you otherwise, both of my W202 MB Manuals do not agree with you here
"1.) "high beam headlamps" = yellow lights next to the low beam in the head light 2.) "combination switch" = "stalk" 3.) first pull = "front fog lights in apron"
Your high beams should not be yellow, if your low beams are not yellow how are your high beams going to be a different color when they are the same exact bulb just separate filaments inside the bulb?
First pull activates fogs in headlamp. ALL of the W202 books I scanned in do say so . Many states in the USA are required to have lower fogs connected into the tail lamp circuit anyway. (I can link you to some statutes) So unless this other forum can somehow give a legitimate explanation or reason why this is different, I'm inclined to go by the books, nothing personal brah. Please post the link as I would like to figure out why this is so confusing.
Old Jun 17, 2010 | 07:39 AM
Originally Posted by appatula
Not pointing any fingers here but I don't care how many people on other forums tell you otherwise, both of my W202 MB Manuals do not agree with you here "
I have HID's..... and the yellow bulbs are next to the headlights, so my headlight and highbeams are 2 different bulbs
Old Jun 17, 2010 | 08:26 AM
  #32
DRBC43AMG's Avatar
Looks like the US C43 are totally different
Old Jun 17, 2010 | 08:40 AM
  #33
appatula's Avatar
95' AMG SeeThreeSix
OMG I THOUGHT YOU WERE RUNNING STOCK HEADLAMPS! Non of this applies then, were comparing the stock MB halogen setup to the retrofitted HID setup that you have!!! Doh!
EDIT: I NEVER knew HIDs were a stock option! Just googled it, I want them!
anyways apples to oranges, just noticed it in your sig to! Still REALLY weird how the factory manuals are contradicting? wtf?
The stock C36 MB setup does not allow you to have the fogs next to the hi/low beam on with the lower apron/tail fogs most likley due to jurisdictional laws in the US. I know Cali has some stringent laws in general. CT statute allows you to have at most two fog light systems illuminated in the front along with low-beams. Some states require fogs to be wired into the tail lamp circuit as well. I'm pretty sure It is unlawful to have hi-beams on at anytime with fogs, newer cars I think actually cut out the fogs when high beams are switched on, you can actually fail inspection in some states if they do not switch off . Stupid if you ask me, the more light the better just as long as you are considerate of other drivers at night right?
Old Jun 17, 2010 | 05:32 PM
  #34
Well I am glad that this is settled I'm not quite sure of the laws regarding fog lights and such here in Oregon but I have yet to be pulled over and I roll around with my fogs on RELIGIOUSLY now that I have converted my fogs to HID. I also don't have a front license plate and I KNOW thats a no no as they want to be able to ticket you using photo radar
Old Jun 30, 2010 | 01:45 AM
  #35
Jovsky's Avatar
2000 C230 Kompressor Sport
Headlight fogs are the inner lights that illuminate in your headlight housing (the yellow ones, yup). The high/low beam is one bulb, you can have only either or on, its the outer light in the housing. I don't seem to be able to get my headlights (high or low), foglights, and Apron fogs to illuminate all at once. It is either headlights and fogs, or headlights and apron fogs. It this strange? My manual seems to concur.
I checked my car's manual. I have a stock 2000 C230 Kompressor Sport (No HID) and the headlight housing consists of 3 "distinct" bulbs namely: Low Beam - H7 (55w), High Beam - H1 (55w), and Fog Lamp - H1 (55w). The fog lamp is located just below the Low Beam and the High Beam is placed where Appatula says where the fogs is located. I tried turning them on ALL at the same time and they did, same as 503C43 has said.
It looks like that Appatula's headlight housing is different since he says that there are only 2 "distinct" bulbs in the housing namely: Low/High Beam and Fog light. The low/high beam shares 1 bulb by having 2 filaments in 1 bulb. In Euro specs, you cannot use the fog lamps if you turn on the High Beam similar to the ones in W124.
Maybe Mercedes Benz has created 2 different versions of headlight housings to accommodate laws that are applicable to each state. I am not creating an argument here. Just my observation.
Old Jun 30, 2010 | 01:57 AM
  #36
I doubt that's the case.... I'm thinking it's more along the lines of the year the car was made as our cars are '99 and '00 while his is a '95 I believe. Thanks for chiming in on the lights though....
Old Jun 30, 2010 | 02:06 AM
  #37
Jovsky's Avatar
Thanks buddy! I was also thinking on the production years but I was not sure on Appatula's car model now that you brought it up. Looks like MB used the 2-light housing for the models 94-97 and the 3-light housing for models 98-00 when they introduced the W202 with factory skirts.
Old Jun 30, 2010 | 02:15 AM
  #38
BOOOOOOOOOOOM!!!! That explains it all...... Thanks for the input
Old Jun 30, 2010 | 09:57 AM
  #39
appatula's Avatar
95' AMG SeeThreeSix
Still, my 1999 C280 had the same setup as my 95 C36? It was purley stock. The 1999 W202 manual also confirms the same setup on corresponding C230 KOMPRESSOR, C280, and C43 AMG. I mean I can't call anyone a liar as it obviously is what it is but my car functions according to the updated 202 99' USA owners manual, (Press time 09/30/98 MBNA/TI/). These things make me crazy!
Old Jul 1, 2010 | 12:11 AM
  #40
MarcusF's Avatar
2002 CLK430
If someone posts a picture from the headlamp switch section of the C43 owner's manual, this could be put to bed.
BTW, with the exception of the CLK's green indicator lamp, the 1995 C36 manual reads the exact same as the 2002 CLK manual.
Old Jul 1, 2010 | 12:29 AM
  #41
Jovsky's Avatar
That's Right! We're not pointing fingers on anybody here on who's a liar. This is just for informational purposes. We all learn something new everyday. Probably, MB introduced the 3-bulb housing late 99 to 2000 as a prototype for W203.
Good job to ALL for the inputs!
Old Jul 1, 2010 | 07:39 AM
  #42
I will today after I get off work....
Old Jul 1, 2010 | 08:50 AM
  #43
appatula's Avatar
95' AMG SeeThreeSix
I did, I did! Both manuals, the pre 1999 W202 and post manual. One includes the C36 and other, the C43.
https://mbworld.org/forums/4101778-post21.html
I still think the manuals side with me but others claim that they are not accurate?
Old Jul 1, 2010 | 05:44 PM
  #44
I referred to my manual and you are correct but if we go by the terminology in the manual it seems to me that the manual doesn't even speak of the apron fogs. Like the thread I ran across and posted earlier I think the C43 is wired differently than the stock W202 as they don't have the apron fogs. It also doesn't state that all of them CAN'T be turned on at the same time but recommends that "fog lamps should be used in conjunction with the low beam headlamps, consult your motor vehicle regulations regarding allowable lamp operation." Not sure but I can turn all of mine on at the same time (and I'm not the only one). Good luck figuring this one out and I hope you can get all of your on at the same time.
Old Jul 2, 2010 | 09:19 AM
  #45
appatula's Avatar
95' AMG SeeThreeSix
The manual does not mention fogs in either version, however, it is assumed that the apron fogs are (should be) tied into the same circuit as the rear taillight fogs. This was how AMG wired them at the factory according to the WIS. Which means unless I can somehow manage to have my selector switch in both first and second "pull out" positions it should be impossible to have all fogs on at the same time. Even if this were not the case the rear fogs and front fogs cannot be on at the same time on a stock W202 and AMG (according to the manual) so if you were to add an apron with fogs they will have to go on one of the fog circuits, not both, still meaning one or the other is on at the same time not both. I'm just going to stick to the book on this one, it seems to work as it should and my sylvania silverstar Hi's are more than enough for even the darkest roads.
As for the 2-bulb and 3-bulb housings, still yet, the manual mentions only two bulbs. Even check your car/year on the Sylvania bulb fitment site, see what you get and post back.
Old Jul 2, 2010 | 12:02 PM
  #46
Jovsky's Avatar
I am attaching here, an excerpt from my manual showing that there exists a 3-bulb housing. The manual has Order No. 6515 0051 13; Part No. 202 584 41 83; USA Edition A 2000
Refer to nos. 8, 9 & 10 in the image for the electrical connectors for the 3 distinct bulbs. Although manual does not state so, I can turn ALL the bulbs ON at the same time.
Old Jul 2, 2010 | 01:03 PM
  #47
appatula's Avatar
95' AMG SeeThreeSix
Very good! That is the post 1998 manual that I am missing . Confirms the 3 bulb setup for HID setups right? Although you can have low beam, high beam, and foglights inside your headlight housing all on at the same time, my original point still stands. You should NOT be able to have apron fogs and taillight fogs on WITH the fogs in the headlight housing. Please check your manual to confirm this, first pull on selector switch is headlight fogs, second pull is rear fogs (and or apron fogs for AMG)? Wondering if the OEM HID setup has a different selector switch setup at this point....
Old Jul 2, 2010 | 02:07 PM
  #48
Jovsky's Avatar
I'll check on the manual later and get back to you guys later with the documentation. I'm at work right now and the manual is at home. I don't have any apron fogs in my car so I cannot confirm if they would all light up at the same time. But, what I can confirm is that the High Beam, Low Beam, & Fog Lights DO light up ALL at the same time. Maybe 503C43 can confirm with regards to the apron fogs if they light up together with the other 3 bulbs.
Old Jul 2, 2010 | 03:22 PM
  #49
appatula's Avatar
95' AMG SeeThreeSix
This has gone all over the place and way off topic. We were comparing HID setups with regular filament setups. Three bulbs all on at the same time? Absolutley, your manual confirms that.
Lets ask this, can you have your high beams, low beams, fog light, AND the rear fogs on ALL at the same time?
This was the original problem I pointed out way back in the thread to 503C43 before going off on tangents. When I switch my rear fogs on (second pull on switch), it disables the foglights in the headlight and turns on my apron fogs as well. Another forum member's C36 did the same thing. The manual states first pull is fogs, second is rear fogs. I assume this means BOTH cannot be on at the same time? My W124 worked the same way my C36 does. WAYYY back in the thread 503C43 said his does not function like this all this other stuff was brought up after the fact and was dissimilar to my setup therefore creating further mass confusion.
Old Jul 2, 2010 | 05:23 PM
  #50
This is getting ridiculous...... I have HID's and have a 3 bulb setup like the one shown above. I just went out and checked AGAIN and I can have everything on at the same time. 1st pull = apron fogs, 2nd pull = apron fogs + rear fogs, 2nd pull + combo switch pushed forward = low beams, high beams, apron fogs, and rear fogs all at the same time. I wish I could take a picture to show you but obviously you wouldn't be able to see the rear fogs at the same time as the front lights. Can we put this to rest??? Does it matter that I can have all of my lights on at the same time and apparently jovsky can too. Once again it might have something to do with the fact that I have a '99 and you have a '95, not sure but I am not lying about how my lights work and I checked the wiring, housings, and switch's and nothing has been altered. I don't want to argue or start fights as I value your opinion appatula, you seem to be in the know on W202's as well as a respected MOD king but clearly we have different set ups (C36 vs C43), different years ('95 vs '99), as well as different headlight set ups (halogen vs HID)... Let's put this thread out to pasture
