Cruse Control on 95 C36AMG issue.
Below that the cruise runs dead on and is very smooth, above that it engages for part of a second and then just switches off.
Any had a similar issue, or know what might be the issue?
I haven't used the cruise control for a long time now, recently i had my tires changed and the size i went for is not the stock ones
Fronts are 235/40/17 which is abt 2.2% smaller than the stock size
Rears are 255/40/17 which is abt 1.1% larger in diameter than the stock.
Question is can this be the cause of the issue? and if so how come ASR is working fine and accurate?
thanks.
.I currently have 225/45/17's (snow set) on all four corners with no problems yet I have read about other C36 owners having ASR problems with the same setup...luck of the draw? BTW I SWEAR I will remember to grab a caliper from work today....
So it can be that my 202 uses a something close to what a CLK uses.
thanks for the explaining thou, i never knew it did all that.
