Vibration in engine at take off
#126
1999 C43 AMG, 2005 E55 Wagon
Thank god I found this post. I'm feeling this horrible jerk the same around 1700-2000rpm when taking my foot off the gas. I thought its the transmisson. I just had it serviced recently. And had the engine mounts replaced too. So you guys are saying its the U-joints? Are those called cv joints? Also you guys recommend changing the center drive shaft bearing? When I did my diff fluid my uncle said it looked changed but, he could be wrong. So I probably should change that too.
#127
1 Post
1998 C43 Amg
http://www.partsgeek.com/catalog/199.../cv_joint.html. So this is the cv joint right?
#128
I read through this whole thread, wish I knew where the "u joints" are in a C43. Still unsure if he was talking about the flex disc? Inner or outer CV joints in the rear? I'm confused!
