Vibration in engine at take off
I was checking something else with the car in "N" and revved up the engine...... there it was, the vibration. Sooooooooooooo I was thinking it was the drive shaft but with the car in neutral and the vibration still there it has to be engine right? The vibration occurs around 1800 rpm and goes away after you pass around 2200 rpm. I feel the vibration in 1st and 2nd but I don't feel it it any other gear (could still be there i just don't feel it). I had the car on a lift when I was changing the flex disc and the motor mounts and tranny mounts looked new, could it be the harmonic balancer or torque converter?. I am at a loss
, can someone PLEASE point me in the right direction.
Also check your eninge mounts visually. On a V8 it's unusual to collaspe though, they usually break first
P.S. If you want to fall in love with your C43 all over again, cut the exhaust pipes right before the secondary cats and FIRE HER UP..................
If only it was street legal............
It turned out to be the gearbox.
And even on my 1981 280CE i once had a similar vibration and it was a gearbox.
Any way make sure u check the rubber couplers of the prop shaft.
...... so let me guess I will need a NEW tranny to fix this issue?
theres a recal on the balancer
